I have found, but not sure when they came out? The ELCB-v had some problems, but the move to ELCB-c was in the main to 100 mA in some cases 300 mA devices, and although it would trip out the whole house, it did not do it that often. It was only after the move to 30 mA units, that the problems really became apparent.
was fitted to my dad's first house (1954) and my house (1978) with very little change, but there were a few problems, one main switch only rated 60 amps, and two no way to add RCD protection for selected circuits, so the consumer unit was born, which is a type tested distribution box designed for use by the ordinary person, but early versions used MCB's where it was easy to fit them without them clamping the buss bar, with clamp on wrong side of buss bar, and often only allowed some MCB's to be RCD protected, and often many MCB's were fed from the same 30 mA RCD, and at 30 mA the RCD tripped too easy to be shared by many MCB's. So we needed a box which could take RCBO's and reassure the public that the consumer unit was safe again, which was done by using metal, although this did introduce other problems at the same time.
as being awful, but we don't know what voltage was used, and I have seen the battery rooms in old Welsh houses, with the shed which had housed the generator now turned into a garage. Not a clue what voltage it used, but the lower the voltage, the less batteries are required.
Yeah - stick to electroboom.I came across that, a few weeks ago - good, but a bit jokey for my taste.
Saw this - quite a few inaccuracies.
So fluorescent lamps needed an earth.13th edition said:Lighting fittings using filament lamps installed in a room having a non-conducting floor, mounted at such a height that they cannot readily be touched and are out of reach of earthed metal.
This translates to about 8 kWh daily. However, this is just an average, and individual usage can vary based on factors like household size, appliances, and heating system." Well, I know my home average use is around 12 kWh per day, and I don't have an EV or electric heating.
The problem I find with dates, is it's easy to find documentation on when a standard was written, but much harder to find documentation on when the items covered by that standard became common.I tried to look at dates, we know when the 13 amp plug came in,
BS1363 was introduced in 1947 but I've always got the impression it didn't become "the norm" until much later.
Not sure if I could hack it today, I hear my son talking about drives, and I just nod my head, I would need to retrain before I could return to the trade. Gone are the days of the dash pot, and using heavier oil, so the motor had a change to start. As to auto-transformer starters, and resistive starters, the 6 stage resistive starter is something for the history books.
