Concrete pillar top cast cap mix
23 May 2004
I want to make a shaped cast concrete cap for a brick pillar.
Overall approx size is 50cmx50cmx20cm.
What is the best mix (sand types) and what additives should I use?
Wouldn't it be easier to just buy a ready made one. The materials will probably be just as expensive
Pea gravel. Screed sand (sharp sand). Cement. Release agent for the shutter box surface. Not sure I'd use any additives.
Four parts pea gravel - two parts screed sand - 1.5 parts cement - mixed well.
Probably.
Thanks for the replies.
Can't find a suitable cap to buy, so will have to give it a go.
My dad cast these about 40 years ago, normal concrete with a bit of extra sharp sand in a wooden mould. They're the shape they are to stop the local teenagers from sitting on the wall when that was a thing. A mate of mine used to make concrete stuff - slabs, gravel boards etc and used a vibrating table - so if you could replicate that somehow? Maybe a hammer drill with a big bolt in against the sides of the mould.
Or borrow the wife's 'other' husband :LOL:
Made a box mold and sculpted the top by hand.
Used sharp sand/cement mix and vaseline on the inside of the mold which worked well.
Thanks for the tip about the drill/bolt.
Not too many air bubbles, and as it will be painted can use a bit of 'rock solid' filler.
Now just got to get it on top of the pillar.
Given the weight, thinking it might have been wise to cast in place! :unsure:
