Doesn't ring any bells
Just to be clear you are saying U is influenced by the order of Sum R?It does in terms of thermal mass. there's a tiny risk (1 degree difference) of external heat penetration with internally insulated (solid) walls.
It depends whether the insulation is used in conjunction with a (stagnant) air gap.That’s nonsense.
The exception when it comes to insulation is if you have it on the inside of your wall, which can create a "small additional risk" of overheating by one degree Celsius or so, but only if your home isn't well ventilated anyway, explained Prof LomasJust to be clear you are saying U is influenced by the order of Sum R?
I'm sure between you, by the end of the night, you will have come up with your own formula.
About grammar ?Doesn't ring any bells![]()
Solar Reflectiveness. Changes the surface temperature, not the U value.I meant the external face, whether that is render or whatever, is usually light coloured.
It's much better than you have done with your misunderstanding of your own links.I'm sure between you, by the end of the night, you will have come up with your own formula.
Reading his posts, he gets told the spec by architects and customers.Yep that certainly appears so, I’m genuinely shocked that a builder could have such a poor understanding of the subject.
Pfft.
The bloke is an illiterate dunce.
It does with IWE.Which part of the building's mass comes within the insulation envelope is an extremely important design factor.
The science is sound, the formula are sound and have been used for decades. As has been discussed, the rate of loss gain is a factor of U and the difference in temperature. It is that last part that is impacted by solar gain.Which part of the building's mass comes within the insulation envelope is an extremely important design factor.
You still haven't explained why all the studies show that external insulation is best for reducing overheating. Maybe you should take your head out of the science textbooks and consider real world data and design practices.
Waffle.The science is sound, the formula are sound and have been used for decades. As has been discussed, the rate of loss gain is a factor of U and the difference in temperature. It is that last part that is impacted by solar gain.
