- Joined
- 24 Jun 2025
- Messages
- 9
- Reaction score
- 0
- Country
Hi, first post!!!
Ive looked at other posts, some 8 or 9 years old when induction hobs were smaller and lower power. Modern hobs appear to have higher power features eg boost, ring bridging etc. I am hoping to install a typical 5 ring (80 to 90cm), typically rated 9 to 11KW.
I wish to replace the existing separate electric oven and electric ring hob with a new electric oven and new induction hob. I have the new oven, rated at 3.5KW. I have not bought the induction hob, hence the question,...what would be the max rated induction hob that can be fitted? The existing "cooker" circuit has a 32A CB, and the current hob and oven are fed from one switch by separate 6mm T&E.
I am hoping to fit a new 45A DP cooker switch, feeding a double outlet plate with 6mm T&E and then running 6mmT&E each to the new hob and oven locations. Some finer points.....
1. The existing cooker switch is midway between the new hob and oven locations, about 2metres cable to each. It has a single socket which I would like to keep, but not essential.
2. Would upgrading the 32A CB (to say 45A) be an option. Replacing the cooker radial circuit wiring is not an option.
3. I understand DIVERSITY allowance could permit the hob max rating I wish (ref Appendix A of the IET's OnSiteGuide) but it would appear diversity requires a certain amount of assessment which the local jobbing electrician may be reluctant to apply (or am I doing them a dis-service, sorry).
4. For clarity, what aspects of my "project" would require installation / certification by a qualified electrician?
I am a retired aircraft engineer, so quite conversant with the technicalities but lacking the knowledge of domestic wiring regulations.
So, in conclusion, what is the max rated induction hob I can pair with a 3.5KW twin oven on a 32A cooker circuit. If not, what are my options (please dont say a smaller hob!!)
Oops , rather a long question, sorry
