No oil, and I have seen a huge reduction in oil use since using the immersion heater. I have no tank thermostat, so I had to guess how long to run the boiler for, I found ½ hour 4 times a week would give me warm water, but not hot water like I am getting now, and the boiler would turn off after around 20 minutes so more like 25 kWh per week used with oil, and I could simply turn down the thermostat with the immersion heater, so looking at 10 kWh extra to heat with oil.
The cost of oil v electric is not the only consideration, as the oil heats up pipes which go through me living room, so also heating up the living room more.
You are correct about the 15p/kWh I would get if exported, so I have set the iboost+ to also use off-peak, as that is only 8.5p/kWh, but there is no way to stop it using solar, and the cost of fitting a time switch instead of the iboost+ is not really worth it.
It does seem I got it wrong, I really did think the jacket would half the energy used, but it seems no, seems it does not save a thing, the airing cupboard is only just big enough for the cylinder, so maybe the cupboard its self was doing most of the insulation?
