No, if the second is connected somehow... joined on same N bar then, or there is a shared neutral out on the circuits, lighting for example.
As for the RCD operating time and the difference they will always vary in their response time, no two identical units will work at the same speed, brand new ones may be close in operating speed but not identical, to get identical all the variables would need to be the same, take operating temperature how would you control that in a consumer unit , how would you measure it, if temperature increased what happens to resistance and the speed of the wave that triggers the rcd components, faster or slower ? Is the connection between the RCD and its circuit as good as its neighbour, does 2.5n/m give exactly the same connection every time, is the copper a bit oxidised. Are the components exactly the same, any variation in the iron core, different destiny ?
Then there is the condition of the rcd over time, does one rcd have a harder life, is it on the downstairs sockets, whats the effect on the rcd components being hammered by the wave of electrons, that's why they are tested to see if they are still within their design spec as over time the rcd components will degrade and affect the response time. So hence we have a maximum permissible disconnect time ... lower than 40mS AND greater than 30mA.
