Internal door quality
2 Dec 2013
How much difference in quality do you think there is between e.g. a £75 pine internal door from Wickes and a £120 one from Climadoor?
The Wickes doors in particular have some terrible reviews, not all from people who have used oil-based paint causing them to delaminate.
Are these doors all equally rubbish, or do they improve a bit if you spend more?
I am specifically looking at 4-panel pine; they don’t need to be fire-rated.
pine is pine and if you are painting it white then there is no point in buying pine - just get ready finished white gloss wood grain faux
de laminate pine sounds a bit odd - i would understand it if it was veneered oak de laminating but who makes a door with pine veneer
I used the panelled clear pine wickes doors throughout my house and they are absolutely fine after 6 years. Most unglazed, two with the edwardian etched glass panels. I recommend them https://www.wickes.co.uk/Wickes-Ski...e-4-Panel-Internal-Door---1981mm/p/9000281479
I see there are a handful of bad reviews. I guess there are always a few rogues, but probably the majority of people who use them don't bother writing reviews. Like me.
Wickes doors are engineered timber i.e. laminated over a core. Personally, knowing how ordinary red/white wood these days is renowned for it's stability (not) I would rather have engineered than solid.
Wickes doors are fine, as long as you pick them in store yourself because they sell a lot of banana shaped doors (and woods in general).
I used to have them before fire doors and they were perfect.
Although, I varnished them with water based (ronseal diamond hard) not oil based.
Pine doors are solid pine . Link to your pine laminate?
Choose any “pine” internal door from any DIY shed or any online door supplier. Example:
Quote: “Constructed with a durable particleboard core wrapped in a beautiful radiata pine veneer”.
Thats veneer not laminate. DOOH
Well I should have listened to the reviews. I’ve spent the afternoon hanging it and giving it a first coat of varnish, and 2 hours later it is starting to crack, bow, fail or peel. The pine veneer has raised in a hard blister in a few places:
The varnish is a Ronseal water-based satin product.
See the terrible reviews here:
What a disaster. I could certainly return it, but then I have to choose an alternative door (back to my original question, are the more expensive ones any better?), and then spend another day fitting and finishing it. Or, I could try to flatten the blisters!
