I would agree, however the Government says it must turn off in daylight hours.Modern LED lamps use so little electricity, and last so long, that trying to save a few pence with the "off" time is not worth the effort or expense.
So it seems we do need to have a control even if not economical to do so.Part L said:6.60 Where installed in a new or existing dwelling, fixed external lighting should have both of the
following controls.
a. Automatic controls which switch luminaires off in response to daylight.
b. If luminous efficacy is 75 light source lumens per circuit-watt or less, automatic controls which
switch luminaires off after the area lit becomes unoccupied. If luminous efficacy is greater than
75 light source lumens per circuit-watt, manual control is acceptable.
If you wanted on at dusk, off at a set time
Anywhere that sells Steinel products.Any idea where I can get new photocell
Unless you have a photocell switch that turns on when power is applied.Use a time switch to provide power ON at sometime during the day and OFF at the set time
Use the switched power to feed the lamp via the photo-cell's switch
Now, why did you specify Steinel.Anywhere that sells Steinel products.
Regarding economy one has to be so careful with this sort of device.Interior switches, out of the weather and direct sunlight, last a long time,
but you will save more money by leaving it constantly On.
As consumption went up, the electricians re-checked and gave the all clear, We were then asked to look at the meters. I happened to be still working on the project and spent much of a day in a riser in the lift lobby, from there it became quite obvious the lights were on for most of 9 hours of the day and beyond to a lesser extent so very minimal saving, however the PIRs were powered 24/365 including the relay at say1W plus it's relay at say 0.5W while the lights were on. Therefore adding 9x0.5 and 24x1 Wh per day or 10KWh each per year x~42 or 400KWh per year. OK not a huge amount but, as it turned out, a measurable increase.
Wasn't there a theory once that for commercial newbuilds, you'd save money by not paying for light switches and all the cabling thereof to be installed and just have all the lighting permanently on? I think the life-shortening powering on for fluorescents may also have been factored in.
Yep, we worked on 60 minutes and even started installing 60 minute timers until the enormity of the task and cost was realised.I heard, for fluorescents - wear and tear, versus leaving them on, power wasted, if you were intending to return to the room in less than 90 minutes, then cheaper to leave them on for that 90 minutes. That was many years ago.
