2x4 I believe the purlins are. I believe that there are 2 struts on each purlin, staggered. So the 2nd strut on the right hand side purlin in the image is behind the camera and you can just see the second strut on the left hand side purlin in the bottom left of the image.all depends on size of purlin, it may have been designed to as a cantilever support for that section of roof. Is it just that one strut centrally placed and it has stood the test of time
2 x 4 seem a bit flimsy for cantilevered supports, although it may be cantilevered design at the 2 different ends of the purlins, may be something to do with the position of the supporting walls beneath the struts but impossible to give a balanced view without the full picture of layout/sizes etc, back to the test of time logic!!2x4 I believe the purlins are. I believe that there are 2 struts on each purlin, staggered. So the 2nd strut on the right hand side purlin in the image is behind the camera and you can just see the second strut on the left hand side purlin in the bottom left of the image.
Sorry if it’s difficult to explain, can you help me understand what the cantilever design would be in this case/how it would work to hold the roof up securely? No knowledge of this stuff and no idea how it would work!Its lasted a hundred plus years. Probably cantilever as stated. Just add C24 length of timber bolted to the wall underneath
It means the purlin is supported on props, albeit those props are not at the ends of the purlin, rather they are somewhat set in from the ends - hence cantilever.Sorry if it’s difficult to explain, can you help me understand what the cantilever design would be in this case/how it would work to hold the roof up securely? No knowledge of this stuff and no idea how it would work!
