Tracksaw advice
3 Feb 2020
Ive got a job coming up which involves cutting lots of 8x4 osb into strips of identical width
I have absolutely no knowledge of tracksaws in use
Ive previously just clamped a nice piece of par to guide the circular saw for similar smaller jobs
I could fabricate a setting jig to reposition my timber guide rail after each cut
My question is would a tracksaw be significantly easier / more accurate than that?
Of course we all love new toys but not having ever seen one in use I dont know if I can justify the price given that it wouldnt get used that often afterwards
Any thoughts?
yes , I dont have a tracksaw - i do the same - using various straight edges - metal rather than PAR
A trend guide - purchased when on sale - goes out 4m I think maybe more
and then for cross cuts a metal guide - i got from toolstation - faithful or silverline i think - but i clamp it on rather than use the clamp things that come withit as they are useless
But my son-in-law has a mitika and its so much easier once setup
i suppose you could then sell 2nd hand once used
Also you will need a long track if cutting 8x4 along the 8' side
I seem to get good accurate cuts - using a template to make sure the Circ saw is in the correct position, allowing for waste and always cut with the waste to the right of the saw - then i account for the waste
I have a template for each type of blade i have - Freud and Saxtontools
As a DIYer i find i cannot seem to justify the £500 odd quid
not sure how good the cheap ones are / shops like aldi/lidl - peter Millard on youtube has a lot of videos on various tracksaws - worth a watch
Done a lot of DIY cutting this way - Just last weekend cut a worktop and some Ikea cupboards down
If on a bench you could set up a stop - make sure to include the blade width as on waste side , and then just move the OSB to the stop and cust
BUT expensive
Peter Millard on YouTube has everything you need to know about tacksaws.
To answer.
You can throw some polystyrene sheets on the floor or build a bench like Peter has done..
Cut away.
You are going to need a long rail and he has another video on the different rails and what fits the saws. From memory I think evolution saw and track would be your best bet unless you want festool.
Some rails won't fit some brands of saw. Festool rails are the standard design and fit a few different saws. There are some cheaper copies of the festool saw rails although I don't know what the current standing is.
My saw and rail was a B&Q own brand for under £100
Looking online it's £189 for saw and 2.8m track.
I have a smaller track for cutting the bottom off doors
Are tracksaws significantly more accurate/easier for repeat cuts than a homemade guide rail and a setting stop/jig?
Maybe not if you have it setup for repeat and cut.
In what way would the tracksaw improve things regarding resetting for repeat cuts -is there some sort of width stop like a circular saw?
I would have to reposition the track for each cut what method would be used?
No , as mentioned in 1st post - you would need to set that up - see peter millard videos
I cut a bit of timber - so its the exact size from the end of the circhular saw plate and saw blade
in fact i did for each blade that i have - as they have different kerfs
then metal guide rather than PAR , unless absolutly straight - which i have not found - i have used furniture board with the laminated edge before - I got the trend guide - also i have used clamps and also double sided tape to keep the guide down on the material
You'll be better off with a cheap table saw
No.
2.4m feed in one side with 2.4m the other.
You need a 5m long area..
How would you get a 1200mm wide sheet on a small table saw?...
We have a massive table saw at work to cut sheets.
Table saws aren't very useful for DIY unless you hobby making small things
That is the complete sentence.
Table saws exist to cut up large sheets of material - and if that is a regular thing, it would be better served by a vertical panel saw.
Those who believe otherwise have been watching too many videos of people in North America using table saws for everything they were never designed for.
I have a cheap erbauer (refurbished eBay) and 2x 1.4m tracks (minimum for 8x4).
The track system provides the level of precision that you just won't get from a circular saw pushed against a length of wood, or even a jigsaw following a pencil line - so it depends how important that is.
The input is greatly appreciated
I initially mentioned what is important to the job, is that every cut piece is an identical width to the last.
I used a timber guide and a large circular saw once before on the similar job with acceptable results what I need to know is what other significant advantage (prescise line noted) has a tracksaw if the whole thing has to be repositioned each time in the same way as a timber or angle iron guide?I
Woody - I have a cheap table saw- one of my most regrettable purchases.
I have a first generation Festool track saw. It is accurate to 0.2mm. It is great for sheet materials, but little else.
A small retail table saw is less likely to be accurate- and yes, I have used proper 3 phase table saws in the past.
I have single Festool guide rails long enough to cut 8 by 4 sheets, you cannot do that accurately on a tiny counter top table saw.
Edit- if you have a supplier with a wall saw, why not get them to do the repetitive cuts, 50p per cut will be cheaper than doing it yourself. They will then deliver to you.
In west London. I use B&B timber. Asian guys, Southall. Consistently reliable. But provide them with the cutting plan when working with multiple sheets.
And they deliver on time, and on cost.
