as wayners says - use a chemical resign and bolts - have now done this on 3 Gates , 1 in the current house - actually used a 4x4" post onto a breeze block wall - the gate rarely gets used
I used some threaded bar 10mm from toolstation
Can’t find a standard bolt to fit the job? Choose this M10 threaded bar instead – it comes in a 1m length and is easily cut to your preferred size.The mild steel threaded rod is a simple but reliable solution for achieving a long-lasting fix in custom fastening jobs indoors and outdoors – a...
www.toolstation.com
and just used a fostner Bit to sink the nuts into the post - looked fine
As screwfixx links dont work - used this resign
Easyfix Styrene-Free Polyester Resin 165ml (292PX)
i see screwfix have STUDS 130mm - so depending on how you are mounting the 4x2 100x50 post - they may do if only using the 50mm side - but if fixing the 4" - i would want more than 30mmish in the wall personally - BUT just a DIYer
Easyfix Studs Silver M10 x 130mm 5 Pack (17513)
1 gate in our old house, used all the time and 6ft high - used all time and worked for Years
