Lithium cells clearly do have some problems, but as long as treated with some common sense, they can also have a lot of benefits, so either have them very small, so problems are limited, or where it is unlikely to be damaged, and in a narrow boat they are unlikely to be damaged, what one would not do, is fit them to a car, where there is a risk of a crash damaging the battery.
This is why I just called them Lithium.One video, seemed to be suggesting, or confusing lithium cells, with them maybe being LiPo4 cells, which are supposedly the safer variety.
Lithium powered boat destroyed in Northamptonshire
Haven't watched the video posted above but a lot of the so called "unexplained" fires involving lithium ion batteries could actually be caused by user error or misuse rather than an inherent flaw in the lithium ion batteries itself. One example of a major issue is when people try to jumpstart dead battery packs by connecting them to a fully charged one without understanding how the (BMS) works or checking the cell levels. This lack of knowledge can easily lead to overcharging or overheating putting the battery at risk of failure or even fire. The real problem here isn’t necessarily with lithium ion batteries themselves, but with how people handle them withoutt understanding the correct charging practices or the function of the BMS. Many of these so called "unexplained" fires could be easily prevented if users knew how to properly maintain and monitor the batteries.Lithium cells clearly do have some problems, but as long as treated with some common sense, they can also have a lot of benefits, so either have them very small, so problems are limited, or where it is unlikely to be damaged, and in a narrow boat they are unlikely to be damaged, what one would not do, is fit them to a car, where there is a risk of a crash damaging the battery.
Most are caused by user error or missuse, the resulting damage is often far greater than the damage caused by abuse of a lead acid battery.could actually be caused by user error or misus
They indeed do but a lot of people argue that its not the users fault.Some lithium batteries self ignite when they are not connected to anything,
I can see the reason for fitting solar cells, batteries, etc. But being Eco friendly is not one of them. I have to agree with him there.
We grow trees, we cover up the wood, allow it to compress, then dig up the coal and burn it. Which is no different to growing trees, and burning them without storing first.
By burning fossil fuels we are taking carbon that has been stored over 1000's of years
A significant number of lithium fires occur when the battery is neither being charged nor supplying power.
you would clearly need to balance that up by how many lithium battery canal barges there are - if there is only one then 100% is not goodAnd your point is?
Would you care to report on all the narrowboat fires not caused by lithium batteries? There are lots, after all.
Or do you have a prejudiced narrative you wish to promote, which would not be assisted by such reporting?
PS - I've just done a search for all the posts you've made containing the word 'lithium', and yeah - it looks like you do.
Just take it to one of the forums for the swivel-eyed, please.
I would ask you to compare the damage caused by lithium battery fires vs the damage caused by other causes.I'd ask you for the statistics of boat fires caused by lithium batteries vs other causes.
wonder if there is a connection with all these wildfires and lithium batteries - just saying! could be being hushed up ......
