Cable clips
Maybe try no nails, put a blob on and push the cable into it and clean up...
Sorry if that sounds rubbish I can't think of another way
You mean a blob using a nail gun? Would this be a good idea do you think?
Or these
Might just order these.
Anyone know what size screw would be perfect? Preferably stainless steel
Would these be a good alternative for clips?
They would work, but look untidy. Either your original idea, of the two hole fixing saddle clips, or single hole P-clips. They sell copper P-clips, as used for Pyro cable.
I like Freddie's idea, of the screw in sockets. You can also buy a similar course screw in type thingummy, intended for plasterboard, which might work out cheaper, and work as well. Any decent hardware shop should stock them.
Your screws will have to fit both the P-clip, and the thing you end up putting in the wall.
Only you, knowing what your insulation is like, can really decide what will work with it.
What screw diameter/length is used for p clips normally? Length I would go for probably is 40mm but i need help with diameter
