Hi All, I've had a good use of this oven for the last 10 years, but if it's worth it to repair, I would like to try to do this.
Oven is not turning ON or showing any signs of life - no beeps, no display, no fans.
The top grill element stopped working, a couple of weeks before the oven completely stopped working - maybe a dying heating element has killed the Main PCB?
In the past, I had to replace the SN-BF63 (https://www.espares.co.uk/cooker-ov...0&shop=samsung&path=574528&model_ref=14040047 ) Oven Noise Filter Assembly a couple of times in the life of this appliance, which has been an easy disconnect/connect job.
I had a look, this time, it might be something else, as checking for voltage with a multimeter - there is mains voltage getting past the Noise filter, up to the main board. Visually, I can't see any burned components on the board or any other components ( as when the noise filter went - it did have a black burned-out mark on it.
Where do I start with troubleshooting this? I have attached photos of the main components from the mains to the control board and display board.
