- Joined
- 27 Jan 2008
- Messages
- 29,346
- Reaction score
- 3,608
- Location
- Country
Last year, a micro switch in the motorised valve stuck, so decided worth testing all is working. Last night I noted the TRV in wife's bedroom was cold enough to bring the heating on, and thought I had heard it working, but latter clear not running, so this morning it was a trip to the flat to test all.
The Wiser wall thermostat first took it just above room temperature, the icon changed in the app, but the hub did not do a thing. So tried Nest Gen 3 thermostat next, that fired the boiler up straight away, then noted the Wiser hub show the run light, so turned Nest down, heard it click off, and boiler still running as expected, so turned the wall thermostat down, and it did switch off, so now try the TRV, noted the tick on the app then the flame on the app, but it was a few minutes before the boiler fired up.
Allowed the boiler to get warm for a few minutes, then off again and worked A1, so again tried the wall thermostat, and again quite a delay, it works, but is this delay normal and part of the Wiser algorithm, or is it a fault?
I know with refrigeration after switching off, there must be a delay before switching on again, I see no setting in the app for oil, gas, or electric, so maybe there is a delay? I also know should not turn off the oil boiler until it has fully fired up, but seemed no delay turning off.
The boiler is oil fired, but I fitted thermostats and saw no setting for oil or gas etc.
