Thanks. 50mm or 110mm AAV then.
I understand that it should be... "at least 200 mm above the highest overflow level of appliances on the soil pipe, usually at the top of the vertical stack, vertically oriented, and in an accessible, ventilated location."
Does that mean it "has" to be at the start of the water flush - behind the WC? - or can it be along the soil pipe close to the WC?
Is the key that is has to be before any strap-on waste connections to sinks or showers? - so it can let air in behind the flush and prevent and vacuum following it?
They allow air in, not out.
So in principle, an AAV at the top of any dead branches. SVPs can be anywhere along the run as they breathe in and out.
Quite often, an anti vac on a basin waste will suffice, but each situation has its own requirements.
