- Joined
- 27 Jan 2008
- Messages
- 29,428
- Reaction score
- 3,615
- Location
- Country
I did look at making my central heating what I call "Smart" and ended up with most functions disabled.
I had all great ideas, Nest Gen 3 would connect to my existing Energenie TRV heads, one only intermittent connection, and two it seemed to work the wrong way around, wall thermostat set the TRV head.
It was surpose to learn, the schedule it generated was daft.
And geofencing had to be nearly home before it switched on, and when the ee mast was damaged we lost heating on one of the windiest coldest days.
I fitted Wiser in parrellel and found the TRV turns on too early as next to cold outside wall.
I have 10 programmable TRV heads, but the result is no diffrent to an oil filled radiator with built in thermostat and time clock, not what I would call smart.
OK, I can alter some of the TRV and wall thermostats with voice control, but this was due to poor FM radio reception and the Nest Mini does both.
But I see a post about making a heating system smart, and wonder what is ment by smart?
