Earth question - Shaver socket
A BS 4573 socket is rated at 200mA continuous. It will suffer no issues.
No.
IIRC the BS specifies a maximum of 200mA
And I'm not sure is specifies continous either.
20/115 = 174mA
20/230 = 87mA
It'll only be a Watt or three but they are enclosed.
I wouldn't really think that, even though fairly enclosed, 'a Watt or three' would result in it getting "very warm".
However, if it does, I stick with my "desperately inefficient" - since it would imply that, when loaded with 1A 1W (at 230V) the efficiency would be something between roughly 25% and 50%, a lot lower than I might have expected of 'just a transformer'.
However, if it does, I stick with my "desperately inefficient" - since it would imply that, when loaded with 1A (at 230V) the efficiency would be something between roughly 25% and 50%, a lot lower than I might have expected of 'just a transformer'.
It's not possible to get 1A from them. That's one the design requirements.
It doesn't.
Rated 200mA, no time specified.
The only reference to 'continuous' is that:
The current-limiting device shall permit 200 mA to be carried continuously.
It also states:
These socket-outlets are not necessarily suitable for the supply to electric dry shavers containing battery charging units.
and that part can be seen in the document preview at https://knowledge.bsigroup.com/prod...in-reversible-plugs-and-shaver-socket-outlets
.... It also states:
Interesting, Thanks. Does that mean that they are only 'necessarily' suitable for supplying corded shavers which contain no batteries?
Electric toothbrushes still need to be charged.
I put 3-pin plugs on my toothbrush chargers and use them in the bedroom.
Apart from once when I left the 2-pin on to use on holiday (wife and I had 2 handles at home rather than faff about swapping heads all the time, hence 2 chargers) thinking the plug could be pushed into a French socket.
No.
Cue trip to the nearest hardware store to buy a plug, and the giving of thanks for having taken my Leatherman with me.
Considering shavers had batteries since the 80's ?
I had a shaver with batteries in the fairly early 70s, but that was then pretty uncommon - most were just 'corded' and, I think, that remained the case for quite a while - non-rechargeable batteries only lasted five minutes in a razor and rechargeable ones were not up to much back then.
And RCD's have been required on most circuits for a while, These things really are a joke.
Are you suggesting that, in the presence of RCD protection, isolated suppliers for shavers (etc.) are no longer needed.
I suspect that one of the reasons why these products have persisted is that it is impossible to have any other sort of socket in a bathroom.
I thought that now you were allowed, if they were far enough away from the bath or shower? It's just that "far enough away" rules out most normally sized bathrooms?
I had a friend once who lived in a flat which was one in a large Victorian house which had been divided up. And I mean a large house - the sort where developers loved to buy them up just to knock down, as the whole plot was large enough to get 4 or 5 detached houses with gardens in.
For some reason (probably access to plumbing) her bathroom was the largest room in the flat - it must have been at least 5 metres square.
Exactly - it used to be 3m, fairly recently reduced to 2.5m (hardly worth the change!) - but, as we've both said/implied, "far enough to rule out most normal-sized bathrooms".
I had a friend once who lived in a flat which was one in a large Victorian house which had been divided up. And I mean a large house - the sort where developers loved to buy them up just to knock down, as the whole plot was large enough to get 4 or 5 detached houses with gardens in. ...For some reason (probably access to plumbing) her bathroom was the largest room in the flat - it must have been at least 5 metres square.
It happens - to some extent in my (also 'large') house. One of my bathrooms is about 3m or so by 4m+, but it would still have been a push (particularly before the reduction from 3m),, even if bath and socket were in 'opposite corners'!
