Identify replacement part
7 May 2022
Hi. I've inherited a drainage setup which has split. I'm trying to find a replacement part (in middle of image).
I've Google lens but nothing obvious is coming up and I don't know the correct terms to search.
Or perhaps it is something they needs to be constructed out of multiple parts.
The nuts are for 40mm compression.
Advice/links welcome.
Just go buy some pipe and fitting and replace as that concertina pipe its terrible stuff.
Not difficult.
Bottle of solvent glue and fittings is best. Not difficult to do.
If you don't want that use compression
It's going between the waste pipe and an external fat trap. I wanted a quick fix whilst we wait for a complete revamp of the plumbing.
I think this is too short. The corrugated piece is over 50cm and needs a nut at each end to attach on to the two pieces. But thanks.
Then use a straight section to extend it! In you photo, you show the flexible, which seems to fit to a part, adapting it to an end which included on the part I linked to.
Sorry. Doesn't mean anything to me. I was just after a direct replacement for the part that had split. I'll pop into the local shop next week with all the bits. Sounds like a replacement can be fabricated through a combination of other bits. Cheers.
