- Joined
- 14 Oct 2025
- Messages
- 28
- Reaction score
- 5
- Country
Before I go to a structural engineer, I thought I'd ask some questions here.
I just finished boarding up the loft which of course took ages to do(30+ hours). Earlier this year I've installed the velux window which helped massively with this job. Of course this is a crappy trussed roof and the loft is only going to be used as storage but I had this idea of removing the centre webs and fitting a triangular/angle shaped ridge beam, with rafters screwed in and tied to it and the beam sitting on a small lintel on the internal wall to spread the load, flush with the rafters and supporting the whole roof at the top. I'd keep the end webs which sit against each internal wall and just remove the four centre ones on each side(they are ~58cm apart) This would make the whole loft much more usable and I wouldn't hit my head on them so often.
Bracing everything for the job would be easy, I just wanna know if this is a sound idea. The beam would be ~3.5 meters long only so nothing too crazy, its a semi detached house.
PS
There doesn't seem to be much weight sitting on these middle long webs, that I want to remove, they are quite sloppy right now but the short ones that I do want to keep are definitely tight, under tension and holding a lot of weight.
PS
