Slow filling toilet
Wonder why that is. Even on the video it says it fixes 7 out of 10 times.
Will try replacing the valve. It’s going to be fiddly getting up and under the toilet!
How come?
Please post a picture because usually it's a very simple job.
Arctic Hayes Siamp Diaphragm Washer 29mm 
It literally is identical
They are identical but somehow they don't work.
Here we go. Replaced it, lined it up etc but the float doesn’t do anything
right so I replaced the whole thing with a flomasta. Had to take the cistern off as the valve flow bolt was recessed under the cistern and near impossible to access.
Put everything back, checked for leaks and cistern was filling up properly and float worked.
BUT no sooner had I screwed everything back together, when I flush and it fills up water is heading straight into the bowl as well as cistern.
Aaaaagh. Could the flush also be at fault? What else could it be?
If I ever separate a toilet I change everything. Peace of mind and the kits aren’t expensive
Yes probably should have done that at the same time. I might get lucky and just be able to replace the flush cartridge. For the time being I’ve flipped the washer over.
