- Joined
- 5 Nov 2024
- Messages
- 5,964
- Reaction score
- 2,847
- Country
What valve did you get?Will try replacing the valve. It’s going to be fiddly getting up and under the toilet!
Arctic Hayes Siamp Diaphragm Washer 29mmWhat valve did you get?
How come?Wonder why that is. Even on the video it says it fixes 7 out of 10 times.
They are identical but somehow they don't work.Arctic Hayes Siamp Diaphragm Washer 29mm
It literally is identical
Float seems to be fouling the cistern, can you twist it at all?Here we go. Replaced it, lined it up etc but the float doesn’t do anything
Float is now gone and replaced with flomasta. Now on to the next problem.Float seems to be fouling the cistern, can you twist it at all?
If I ever separate a toilet I change everything. Peace of mind and the kits aren’t expensiveFloat is now gone and replaced with flomasta. Now on to the next problem.
Yes probably should have done that at the same time. I might get lucky and just be able to replace the flush cartridge. For the time being I’ve flipped the washer over.If I ever separate a toilet I change everything. Peace of mind and the kits aren’t expensive
