- Joined
- 12 Jan 2020
- Messages
- 24
- Reaction score
- 1
- Country
I I've this query on another forum, but reading through some stuff on here since makes me think that there could be some useful knowledge as this is a bit more specific.
My local BC have also proved very difficult to just call and have an informal chat with, because that would be a great option if available! I will try that again on Monday anyway.
Lean-to utility room on the back of a Victorian terrace. Single skin brick, no insulation in the roof and damage to the ceiling. The utility room isn't original, but its probably been there more than 50 years, perhaps longer.
I'm finally getting a builder to come and install insulation and a Velux window to let in a bit more light. Because the existing rafters are quite shallow and the area of the roof is small (3x3m ish) they advised just replacing the woodwork and membrane which is all pretty old, which will allow a better depth of insulation. My understanding is that it is effectively like for like and there is no structural need for it, other than they might be able to make the spacing match the Velux window. They will also replace the plasterboard ceiling and an electrician will put a couple of lights in. The same tiles will go back on. The ceiling inside is attached to the rafters and follows the same pitch so there is no void space.
When I asked way back when about BC, the builder said it wasn't normally something they would worry about with this sort of work, but they would help me put the documents together if needed. My reading of stuff as a layperson is that, because the timbers are being replaced, then officially I should get BC involved.
I thought that this level of of minor work could be covered by a Building Notice and I would just write a narrative description of what was being done and submit that to the council. It could be submitted a few days before the work starts. Yesterday evening I asked ChatGPT to turn the quote from the builder into some sensible text I could send to BC if needed, and then was getting a bit more info on the process. It suggested that because replacing rafters is effectively structural, I might need do a full plans application! I'm hoping this is one of those instances where a human knows better.
I think the insulation bit is fairly easy to meet the required regulations on for thermal retention, so I'm not really worried about that. What I'm more concerned about is the structural element. For this kind of work, I can see there are span tables for the spacing of rafters based on the pitch of the roof and the span. Hopefully that's fairly bread and butter stuff and could be submitted as narrative i.e. span is x, pitch is y, roof tiles are made of z therefore 200x50mm rafters will be spaced at xyz.
Edit: I'll add to this that I've just done some quick measurements and the angle of the roof is about 25 degree, the span is 2.1m and the width is approx. 3m (didn't actually measure that one). It sounds like the proposed 200mm rafters are fine, potentially excessive in terms of sturcture. And potentially 600mm spacing.
Is anything else expected in terms of things like foundations? This is where I start to get myself tied up in knots - if this question was asked, the answer would be that I have no idea what the foundations are like. And then does my whole project get scuppered or they tell me I have to rebuild the room with proper foundations?!
Can any help advise? Other than the obvious "BC don't need to know about this". Does the above sound like it is appropriate to just submit as a Building Notice, and might a BC officer want calculations signed off by a structural engineer or is this so run of the mill to somebody that works in the industry that quoting those span tables would be sufficient? Tbh i'd ditch the Velux window at the point if it made my life easier!
