2 way switch and change of cable ?
18 Aug 2025
Hi guys can i ask some advice
regarding making my pendant light
2 way switchable.
im doing some bits in my sisters
house which is a older house then
mine at my house the switch live and the common come down on 2 separate cables and the neutrals into a connector block
however in her house its a different setup
there is only one cable at the pendant and one at the switch and then there is junction box in the loft what they go into
there is 4 cables in the junction box i presume supply coming in supply coming out then switchable supply going to the switch which is then linked in the junction box to the pendant
in this room only would i be able to chance this circuit and take supply down to the switch with live and a neutral and then bring it back up with another twin and earth like you would see in a more modern setup ?
also how would i go about wiring the 2 way switch ?
i will get some pictures up when i take them
once again in advance thanks for all your help
I looked at the problem when we turned the dinning room into a temporary bedroom, wanted a switch at the bed head, the method I used was to fit a smart switch,
yes expensive for the first one, but no wiring involved, as it happened she wanted music so also a smart speaker
which resulted in the remote switch not being required as she could use voice commands. The button was re-used as a doorbell push.
when ou say take it down are you re chasing the walls ??
have a think about maybe remote bulbs/switches maybe
pretty much like this
What are you trying to achieve ?
2 switches to control the light
Or a neutral at the switch because of some smart system ?
Just take a 3 core and earth from the original switch to where you want the new switch
Hi thanks for reply i dont kind of want to go down the way of a smart bulb system this is a empty house and the whole room is getting plastered so im happy to make a mess lets say lol
the whole wiring does want upgraded but thats a cost factor that cant be covered at the moment but while im doing this room at least im gonna redo the cables
here is some images of what i have so from my view
i have LN supply coming into the box 2 switch lives going from the box one to the switch in this room one to the room next door
and then 2 pendant feeds again on for this room and one for next door
so in the change for the new cable im looking at taking live and neutral from this J box down to the switches then cable back up to the pendants
but i want to add another switch in this room next to the bed so it can be 2 way switch on and off at the bedside and on and off on the wall
why do you want neutral at the switches ????
pete01 said -
thats the simplest thing
EDIT
or use a pull cord at the bed :) :) :) - joking , i have installed on e like that in the 80's
regardless whether is a "new" or "old" layout, best thing to do is run 3C+E between the switches.
If you are going to replace the switch drop, leave it long enough to reach a ceiling rose.
The earths aren't connected in that injunction box, bit of investigation needed and a new junction box...maybe.
Thanks again guys for the advise
Yes the earths are twisted all behind on the back of the box
So yeah 3c and e seems the best option
i was just going with the line of taking N to the switch just to future proof it if any smart switch or something ever ended up wanting to be added
So Working from that junction box what would be my run ?
To the first switch then to the next and the rose like how would it be configure
Thanks all once again
Also yeah the cable is pritty old and its on a old board but for now it really is going to have to do with the small upgrades then it will be getting someone in to do the main work at the board and such
Change the original 2c and earth switch drop for a 3 core and earth then while you're messing, and fit a 35mm back box or a 25mm box sunk a bit deeper.
