Electric shower internal leak
10 Dec 2009
Middlesex
Electric shower, triton kiko.
Noticed it leaking from the bottom while in use. removed the cover to reveal the leak coming from the joint arrowed:
Ive not stripped it down but i looks like the joint between the contrasting black and white plastic is bonded in such a way that makes it non serviceable but im wondering what is causing the leak and if there is anything i can do to repair/fix it?
Not certain ,but pretty sure they can separate and O ring seal makes watertight joint between them.
Correct. It's just a push fit with an o-ring.
To be fair the existing o-ring looks to be in good shape and there's no debris in or around the seat.
Will give everything a clean and replace the o-ring anyway and hopefully we should be good to go
Cheers
