- Joined
- 11 Jan 2004
- Messages
- 46,433
- Reaction score
- 3,756
- Country
Leisure firm charged after footballer electrocuted in Portsmouth - BBC News https://share.google/DfH0pMUJ5iQSN1lEZ
Health and Safety Executive inspector Michelle Canning said the mast had become live because of damage caused by it swaying in the wind.
These are helpful in stopping it happening again. The pictureThe jury concluded that a fault to the floodlight had first been identified in November 2015, and another player had then reported suffering a shock in December 2015.
I'm a bit confused. Does your 'earlier report' relate to the same case? The report linked by secure relates to a case not due to come to a Magistrate's Court (let alone one with a jury) until 4th December.What a useless report. Earlier report ...
It was linked to the report @securespark linked to. And had some of the same pictures. So would assume same case.I'm a bit confused. Does your 'earlier report' relate to the same case? The report linked by secure relates to a case not due to come to a Magistrate's Court (let alone one with a jury) until 4th December.
Ah, right - all is now clear (and the situation rather different from what I had thought).It was linked to the report @securespark linked to. And had some of the same pictures. So would assume same case.
Indeed - but I rather suspect/fear that such things probably are not RCD protected. Does anyone know?You'd think so.
In this area many street lights are fed from the network cables without RCD protection.Given what happened, should such things perhaps be RCD-protected, I wonder?
As I just wrote, I suspect/fear that that may be the case everywhere.In this area many street lights are fed from the network cables without RCD protection.
The last I knew street furniture was specified as not RCD protected (but my last involvement was easily 10 years back), on that basis I'd make a guess your suspicians are correct.Indeed - but I rather suspect/fear that such things probably are not RCD protected. Does anyone know?
What about the enclosures themselves - are they not metal? We are, after all, not talking about 'contact with (intentionally) live parts' but, rather about contact with touchable metal parts which may ('accidentally') become live as a result of a fault.However the vast majority of control panels built into this style of enclosures ....... are in very 'controlled' environments with negligable portable kit and low risk of coming into contact with life parts.
Previously called "Indirect Contact", whoh I am showing my age now!What about the enclosures themselves - are they not metal? We are, after all, not talking about 'contact with (intentionally) live parts' but, rather about contact with touchable metal parts which may ('accidentally') become live as a result of a fault.
Well, an inevitable risk when (in the absence of double/reinforced insulation) there is an unearthed exposed-c-p.Previously called "Indirect Contact", whoh I am showing my age now!
It would seem that it probably could have been avoided (hence the current prosecution), if it is true that the fault was identified a couple of months before the sad thing happened.Anyways, a sad thing happend, could it have been avoided?
Yes of course problems and faults can and do occur. However, due to the potential complexity of control systems and the power levels involved, there is potential for hazardous situations, therefore the installations are usually completed and maintained to a higher standard than other electrical work, to keep hazards low and maintain efficient opperation.What about the enclosures themselves - are they not metal? We are, after all, not talking about 'contact with (intentionally) live parts' but, rather about contact with touchable metal parts which may ('accidentally') become live as a result of a fault.
