- Joined
- 27 Jan 2008
- Messages
- 29,428
- Reaction score
- 3,615
- Location
- Country
Full marks on the review google shows around £50 so not cheap, and the app looks very similar to the Kasa TRV head.
Two year battery life is good, the Energenie has a two-year battery life as well.
"you also get six adapters in the box, covering Danfoss RAV/RA/RAVL, Caleffi, Giacomini, M28x1.5 and Oventrop M30x1.5. " This varies, Kasa, and eQ-3 come with the kit, the Wiser has less but a free adapter is available, the Energenie very much reduced, and seemed to have a problem with working out pin travel, the eQ-3 gives a code for under or over travel so you know if working or not. (automatic calibration)
"The W600 works with Zigbee 3.0 and Thread, it can easily be integrated into Apple Home, Google Home, Samsung SmartThings, Home Assistant, Alexa without an extra hub." The Wiser is also zigbee, but I could not link to other zigbee devices, but would link to Google Home, but needed the Wiser hub. The Kasa and Energenie also needed their own hub, the eQ-3 is Bluetooth and does not need a hub, but it will only connect to 1 phone. One point is some including eQ-3 can be paired with other TRV heads, where more than one radiator in a room.
The working with voice commands has a second advantage, in that three different makes (Wiser, Kasa and Energenie) in my case, can be adjusted with a single command.
The app seems the same as one used for Kasa.
The window open detection has not been found with Energenie, but is included with the rest, even the eQ-3 which only cost me £15 each in 2019. I use it to detect the door open when unloading shopping into the kitchen. One can set the time it will switch off for.
The problem with TRV control is radiators often placed against outside walls, if not linked the valve may open, but radiator will not heat unless the boiler is running, but with the linked TRV head, it can cause the boiler to fire. In theroy we don't need wall thermostats, the TRV head can do it all, but where the radiator is on an outside wall, the likes of Kasa allow the use of a wall thermostat to control the TRV head, I don't know if it can also fire the boiler?
At 74, I find working out how to control central heating is not as easy as I first thought. Each house I have lived in has been diffrent. With a modulating boiler I would say control with TRV is required, but with simple on/off boilers, the problem it to get boiler to fire when the programmable TRV head calls for more heat. And we need multi devices which can cause the boiler to fire, so we are looking at how to link the TRV to the boiler.
