I have a repeated problem with cold radiators. I had a local company to look at the system a couple of years ago which seemed to sort he problem for a while but we are back to cold radiators again.
I have a conventional boiler / HW tank system. All piping is plastic and I think that there may be a manifold under the en-suite floor just above the boiler.
The main problem is the bathroom, hall and downstairs loo radiators. The bathroom and hall are stone cold, and the loo is warm but not too hot. These three radiators are close together - bathroom is above the loo and the loo is pretty much back to back with the hall.
The en-suite radiator is warm, but again not too hot and is directly above the boiler. Other radiators seem OK.
Is the system unbalanced or could there be a blockage somewhere causing the issues? If unbalanced would I shut off all radiators (bar the hall) to see what effect that has and then adjust the lockshields in turn. I am not sure which might the last on the ciruit
