That is my worry - spending mor emoney on something and getting the same result.Possibly yes, if done correctly, but there would be no guarantees.
I had my usual plumbers in a few years back for the same issue. They had boards (actually chipboard sheets) up in one bedroom and I think that there's a manifold in that area that would supply the bathroom the loo and the hall. I should say that the runs to the boiler are 22 / 15mm plastic and the rads are on 10mm microbore plastic. I would have to have a look to see how the system is plumbed as the dining room radiator proabbly comes off this manifold and is OK. I should have taken a photo when they were last under the floor!Depends on how easy access is and length of pipework etc, you'd be mostly guessing where the problem is. Are the problem ones far from the main/good pipework? Can you DIY some re-piping?
I suspect a problem in this area of a manifold or on the runs to the rads. I don't think the wife would tolerate more upheaval just yet, so I may wait until the warmer months to have a play with actual piping. I could probably have a go at re-piping some myself - I am fairly handy at most things!
