Surely it would wait for daylightNot much fun, working after dark, with no lighting available, and could be quite dangerous.
Same with me (albeit 'downstairs' lighting circuit) - but the question arose from someone who has alarms which are not quite as easily replacedAlways on the upstairs lighting circuit and as I always fitted Aico it is simple to remove them from their bases.
As I wrote, that is obviously undesirable. However, I don't think it would be particularly 'easy' if there were a key-operated switch.Never give people an easy way to isolate life saving alarms
Hmmm. How long are people going to live in a house with the lighting not working, and how likely is it that an alarm will be (legitimately) activated during the period whilst they are waiting for the lighting circuit to be restored/repaired?Increasing the chance of the fire alarm supply, being lost, if the lighting circuit trips due to fault, and it not being able to be restored.
Quite. As I've implied, I think that alarms on a dedicated circuit could remain without power for a long time, maybe long enough for the backup battery to go flat, without anyone noticing (or understanding the significance of) the LED or occasional brief bleep.Who regularly checks that the LED is lit? Not me, the mains supply could be missing for months, before I would notice. The bleep, every so often, is quick to be noticed.
I was (well, smoke/heat/CO/gas etc.). However, I was asked why I would need to 'work on the circuit', and I replied that the reasons would be much the same as with any other circuit.I thought you were asking specifally about smoke alarms.
Thanks. It's good to have at least one direct answer to my questionI think as John said in the OP would be the best answer. Whilst I`ve never considered having an isolator for them I can see the merits so a yes from me.
... but that's also the second reason why I don't really like the idea of alarms on a dedicated circuit - since it is then only too easy for someone to disable the alarms by operating the RCBO/RCBO in their CU. If the alarms are powered from a lighting circuit, similar action would disable their lighting as well as the alarms!If a fire alarm system is the only circuit, on an MCB/RCBO, then IMHO - that provides all the isolation needed.
See above. If one has decided to run the alarms off a lighting circuit, one would need some sort of switch to 'isolate' the alarm circuitry without losing lighting - although I do agree that the need for such 'isolation' would be a very rare event.Why would a key switch on similar be needed, in addition?
Yes I think it would be good or could be good in your situation as I assume your own private use, not in everbodies situation though.Thanks. It's good to have at least one direct answer to my question![]()
As I've said, it's not "me" - the question came from a 'third party'. My alarms run off a downstairs lighting circuit but I haven't bothered to include any switch/isolator, key-operated or otherwise.Yes I think it would be good or could be good in your situation as I assume your own private use, not in everbodies situation though.
You really are scraping the barrelThat could be days, weeks, however long it might take them to find, and engage an electrician to restore the lighting.
Indeed, and most also flash an LED ....FFS …Smoke alarms bleep when the back up battery is getting low …..for weeks even months ….
Someone might 'notice', but would not necessarily understand the significance.i think someone would notice …
That's what I would do, since I have Aico alarms (although I strongly suspect that the manufacturer probably advises isolation when one does that). However, other makes of alarms are not necessarily as 'simply' replaced.anyway if you fit the AICO smokes all you need to do is release the faulty one and slide in a new unit …no need to isolate anything
