Another Damp/Mould question
11 Jun 2016
Two issues(I think) I have.
First one is the damp/mould in top corner of internal wall. We have CWI & rendered walls. Where we live we do get lots of wind driven rain against the house. What's the best way of finding out if that is the case or would it be better to get a professional in?
The other one is the dark spots above a window. The original window (sealed) was replaced by us last year & we have it open on the jar all the time. The dark patches were there before window replacement but have got worse this year. Doesn't feel damp to touch.
We do dry washing in the house in the small b/room. We have gas ch, bathroom extractor fan & a cooker hood.
Cheers for any replies
Run a dehumidifier in room when you dry washing.
We also use a summer fan to move air around and takes about 4 hours to dry washing along with the dehumidifier.
Looks like you have high humidity so you need to get a dehumidifier and run every evening for 4 hour.
Opening windows and running extractor fans helps but won't cure your problem. Your property is saturated with moisture...
Cheers Wayners.
Looking at the photos i put up, are you convinced it's internal issues & not external.
Very informative video. I never knew opening windows before putting the heating would help with condensation. The wife's Christmas present sorted out now then, hope she likes a dehumidifier lol.
Why run the dehumidifier in the evening & not during the day? Once again, many thanks
In the evening, you are exhaling moist air as you sleep and the outdoor temperatures are lower.
You could aim a fan at the damp areas. Air bounces around corners, forcing air at them might help as a short term fix.
Which is a really bad idea. The moisture evaporated from the clothes, goes into the internal atmosphere of the entire house, then condenses out where ever it can find colder spots in the house - which is shown in your photos.
Do you always, without fail, turn those on? It's important that you do, or that they come on automatically.
We do run in the day sometimes.
Depends on humidity.
Yes. I think its high humidity in your house and not external.
I empty tanks every other day. You wonder where all the water comes from.
Had a quick look at dehumidifier & like everything else there seems to be hundreds to choose from. What things should i be looking for in one?
Don't be tempted by the cheap ones, which claim to remove moisture using a chemical satchet. What you need is, one which uses a little motor, and compressor, like a fridge, plus a fan. Many just have a container to collect the water, which then have to empty regularly, or the stop when full - some have an option to install a small drain pipe, avoiding the need to empty. Worth having that option, if you can add a drain.
We try not to, but sometimes it's not possible to get it outside or use our condenser tumble dryer.
99% of the time they are used. With the bathroom fan, it's left minimum of 20/30 mins after finishing.
We have PureMate PM 465 20L Dehumidifier
Has a laundry setting which is it runs flat out.
I'd buy another if it died
You will continue to have mould where clothes are dried indoors regardless of which room , the damp air will migrate . Adequate ventilation is required and it’s free unlike a dehumidifier .
Opening windows will not eliminate the problem.
Like the Germans sign up for when they rent, agreeing to open windows when it's -10 outside for 30 mins every day will definitely help greatly. It's a really good thing to do to clear the air but It absolutely will not pull the moisture out the walls and furniture.
Won't dry anything in the house.
Won't stop mould or condensation.
I could scream when I read people say fit a bathroom extractor. Open the windows.
It's a very complicated and individual property problem.
There are plenty of videos explaining the problem far better than myself.
I'd say a dehumidifier is a must buy for everyone.
Then better ventilation in the house.
I shut all the windows and trickle vevts when dehumidifier is going.
For some the problem is too much ventilation.
Got that now on a property where they don't shut the windows and the condensation and mould is horrendous!
and Switzerland too. When I stayed in a Swiss mountain hotel, each morning, they put the massive, proper duvets out, on the veranda, and opened all the widows.
I would disagree... Extraction of moisture laden air, at source, is crucial in avoiding mould. If you just open the windows, then the cold air rushes in, maybe pushing the moisture laden air where you may not want it, or to condense out on the walls.
Besides which, the proof of the pudding - we never open windows in the winter, and we have no vents, yet we have absolutely no mould in the place at all. What we do, is always use the cooker hood, the bathroom fan runs every time you walk in the bathroom, there is a ban on pans being used without lids, on the hob, and drying clothes in the main house.
Extraction at source, is more important than a dehumidifier. We have one, but it is wall mounted, in the separate to the house, utility - there for the sole purpose of drying washing, on those rare occasions when it cannot be dried out of doors.
I have worked in many properties with no bathroom windows.
I fitted a humidistat fan at home because I knew that people would not turn on the light if showering at 9am during the summer. I also knew they wouldn't open the window at 6am in the winter.
The humidistat chugged away for as long as required.
Never needed a dehumidifier, never had a mould problem.Opening windows is a poor way to ventilate in cold weather, reduces internal temperature resulting in more condensation especially in bathrooms.
