are not cheap, likely cost me around £150 to get the test gear, and for most people cheaper to get an electrician to do the work than hire or buy the test gear. I admit I don't always test as I should, but if something goes wrong, then one has to get the testers out.
here seen testing the earth leakage, but same meter has non-contact volts test, volts measured with leads, ohms measured with leads, and AC and DC amps with the jaws, so my total earth leakage is 8 mA as shown with the meter. That meter cost me £35. As did the insulation tester, the RCD tester was around £90, so what have you got to test with?I will try another (3rd socket) and see if that resolves the issue. Suspect that was the issue, but after trying it, it didn't work.
I see basically three possibilities.I currently have a twin and earth connected to a terminal block and the circuit is working with no issues. However, when I connect the cables to a electric socket, the RCD trips.
Any ideas what could be the root cause?
You've probably connected it wrong,Any ideas what could be the root cause?
