Garage Roller Door, slides back down after opening
19 Apr 2005
Hi All, appreciate your time.
My motorised garage door will roll back down after opening, sometimes half way and sometimes a few inches. I think I need to re-tension the spring by supporting weight loosening u Bolts and and tensioning by rotating the bar with Stiltsons?
I'm fairly handy but is this something I should get a pro to help with?
Drops half way sometimes before it stops itself.
I've never seen a motorised roller shutter type door, using counterbalance tension springs.
OK - thanks. Any ideas on why this might be sliding down - anything I can do to fix?
my thoughts
assuming its not worm gear ??
the motor will power until it hits a microswitch to stop the motor and in this instance perhaps a sprung latch to hold against gravity
with hand action or an electromagnet to open the catch when "open "selected
perhaps the latch is not engaging??
off course i could be miles out :giggle: :giggle:
