Drayton Wiser two channel replace of RWB9 Siemans Controller
10 Dec 2025
I have a convectional British Gas 300+ S-Plan system with two 2-port zone valves, currently controlled by a Siemens RWB9.
I plan to replace the controller with a DRAYTON WISER WIRELESS HEATING & HOT WATER 2-CHANNEL THERMOSTAT CONTROL KIT.
I have attached a pic of the old wiring backplate, and have sussed that the wiring terminals are as follows:
  • N – Neutral (blue wire present)
  • L – Permanent Live (brown wire present)
  • 1 – Hot Water OFF (not always used)
  • 2 – Hot Water ON
  • 3 – Central Heating OFF (not usually used)
  • 4 – Central Heating ON
  • Earth – Green/yellow (parked on earth terminal)
I haven't bought the new controller yet, but I was wondering if anyone can tell me if I can reuse the existing backplate and what rewiring I will need to do?
Thanks in advance.
Is this the original 2-channel Wiser
I see that's On Sale in Scewfix.
Or the current Wiser 2nd Generation 2-channel? (Which I can't find a manual for on Drayton or Schneider's site). But Wiser were offering me a 40% discount on a new one to replace my older one.
Wiser unit will come with its own backplate and the wiring may need transferring across (with mains isolated). But the terminals should be marked the same I think.
You could be very lucky and find the Wiser can attach and have the fixing screws hold it in place on the existing backplate.
Double and triple check the manual for wiring being identical before doing so and turning the mains back on.
It seems there is a change, in the main terminals 1 and 2 are not used. This
however seems to show 1 and 2 is off the same as Wiser and Hive, so seems you have read the diagram wrong? And they are the same, it is the earth wire which seems wrong, can't work out why ever put there?
According to the installation instructions it should fit onto an industry standard wallplate, so should clip on. No wiring alterations necessary
Earth wire is correct in the earth parking terminal.
Earth wire is clearly terminated on the earth terminal screw.
Two channel wiser is HW ON = T3 as is the Siemens... and CH ON = T4 as the Siemens is.
What Industry standard?
Far too many variants 'in the wild' imho.
Then look at the 3 Wiser wiring variations within the same backplate!!!
:eek:
OP must check; then check again in order to satisfy themselves that it is a simple swap (which I think it could / should be). Or if the Wiser backplate needs to be used for clearances/fixings reasons.
Rodders53, its the 1st gen:
Ensure you are happy that it has recently been superseded by the 2nd Gen and that there's nothing the new one does that you will want to have that the Gen1 can't do. {Other wiser smart items it seems from a quick glance. It may also be faster processor etc.,.
No point in saving a little now if you'll want to upgrade in a short while.
Then buy it and compare the supplied backplate with the installed Siemens one for dimensions, fixing/retaining screws etc.,.
As I recall my "Industry Standard"
Common term for the actual basic back plate.
for the Honeywell ST169 programmer was wrong on a number of counts (not least that my Wiser was the 3-channel version) so I had to transfer cables and do some rewiring for the two CH zones and HW.
I believe you may be more fortunate and be able to just plug and play... but check!
The Wiser is a decent enough system, but the App could be improved.
