Bad Requests (400 Error)
29 Jan 2008
Liverpool
Anyone else getting these?
Seems to be happening over the past few days on my phone and laptop using Safari.
Have you tried.
Reboot router
Reboot phone
Reboot pc
Have you tried.
Reboot router
Reboot phone
Reboot pc
Doesn't matter whether pc, phone or bit of electronics if it doesn't work the advise is always reboot. It works about most times is you are lucky
Shame, it would have been much more useful if the server had said which header it had an issue with. The longest header you have direct influence over is the Cookies header; clearing your your cookies may reduce it (but the server sets cookies, so if it's huge, it's the server's fault). Other headers can be inserted by browser extensions, proxies, etc and you may or may not have control over these
Press F12, go on the NETWORK tab, then refresh your diynot page. Click on the name column of the request that failed, to see an inspector window set in the right hand side, and choose the tab that lets you see the headers. Post a redacted screenshot of that; do not post your cookie in clear text, draw a blank box/blur/scribble/etc over it - want to see the length of the header, not the content
For example, here's a shot of the request headers panel for this page, from my Edge:
Your headers should be broadly in line with these, size wise
Sorry to hear that, I'm looking into it.
Still happening...mostly on iPhone, so can't F12 it
If you want to dig into it on an iPhone it's a bit more of a headache but still possible. I'd say the easiest thing to do is run some software on your PC that turns it into a proxy, and tweak the phone network settings so it puts its traffic through the PC, then the PC can inspect the headers..
I'm getting exactly the same on one of my ancient lap tops - meaning I can no longer post on it :(
My ancient ipad suggests that I have to agree on the site cookies.....yet I can't see any to agree with!
Maybe I should just update my gear, but this equally old lap top doesn't seem bothered.
John :)
John :)
I've sent you a message which should hopefully help.
Apart from the earlier problem, I reported, where clicking a partially read thread subject, should take me to the last read post, it often takes me to a random post I have already read. In addition, I have spotted a new issue which occurs sometimes...
If I highlight part of someone's post, so that Quote comes up - sometimes, no matter what I do, I simply cannot get the Quote to appear at all. That's whether I highlight top to bottom, or bottom to top, or which line(s). I have to use the Quote button, at the bottom, quote the lot, then delete, what I don't want to quote.
I encounter a lot of nuisance behaviours on an iPhone, the predominant one being that it partially logs out/some token expires and nothing on the page works.. The text editor box also has some major glitches but it seems worse with ea h passing iOS version so I'm not sure how much is under diyn's control
