Magnaclean filter leaking at pipe joint.
3 Mar 2013
London
Hi All, Serviced the magnaclean pro 2 as normal (never had issues before), suddenly I turned the isolation valves back on and now it is weeping at the these joints. No amount of pushing the body back in will stop it.
Any advice how to get it to stop? Thanks in advance.
That nut looks corroded. It's gone green. Any water leaking from that?
Paper towels is best thing to use.
Dry off.
Then you the paper to identify leak location
Dry off.
You were 2 steps ahead - I didn’t have a leak there before but I do now!
So now there is the original leak where the magnaclean meets the manifold; and also new leaks at the green nuts!
