- Joined
- 27 Jan 2008
- Messages
- 28,397
- Reaction score
- 3,452
- Location
- Country
Is it a failed standard bulb, or a smart bulb turned off. Reasonably sure this one is a failed bulb, as in the main watts x 100 for a smart bulb is more than the lumen, but for a standard bulb it is normally less than the lumen, so this one going in the bin.Replacement 806 lumen and 6.5 watts, filament type, it says less lumen as the bulb it replaced, but seems to light the room far better, giving off an all round light. And a clear glass bulb, not frosted plastic. If made Jan 2019 not done too bad. Google does not help.
But this bulb is B22d, so the number tells one nothing. Add make and yes
That seems to be the bulb, and not smart type, but don't want to hunt every time a bulb fails to find out if failed or simply turned off in the bulb.
