Replacing extractor spur with timer switch
14 Oct 2016
I have a standard spur fuse switch controlling an extractor fan, but I don’t won’t the fan to activate between 20:00 and 09:00.
Can I replace the switch with a timer switch?
How do you wire the 6 cables into 4 points on the timer switch?
Cheers
Iggy
As said, items like this
can allow control both timed and with voice control. But the immersion heater timer
has for years combined a time switch and fuse. I must admit I would convert to a plug and socket, and use a plug in control
OK, it needs a hub, but I already have the hub, and if it fails, so much easier to unplug and replace to messing around with hard-wired devices.
