Additional CU
19 Apr 2004
Hampshire
I’m considering adding a 4 way CU next to my main one as it’s getting a little crowded and I want to separate the garage lights and sockets and external lights from the main CU. Partly because of the crowding but also just to separate them
I’m a retired ex electrician so doing the work is not an issue. But I need to split the tails into the new CU. Any recommendations as to currently available 100amp power supply to splitter connector blocks to use please ?
It used to be easy as they were mainly just two types of Henley blocks that were used back in the day (70s). MK and Wylex from memory
Everything is isolated by a double pole switch so all safe. I assume, in my situation, adding an additional CU is permitted ? But will need to be carried out by a certified electrician ?
plus if you do not have already , maybe use RCBO - i wish i had those , only had a trip twice , BUT takes out half the CU, although at the time the electrician fitted 2017-8ish ours i think he quote for the rcbo something like £75-£100 each or something like that
Replacement CUs are notifiable; additional ones are not. :)
Henley blocks still available and favoured.
For the ordinary user, I would certainly agree, because the might have difficulty getting someone in to diagnose the issue within a sensible time frame - but for those able to quickly, and easily self diagnose, it is much less of a problem.
A dual RCD CU, seems a fair compromise, if the circuits are organised, so there is always some power available locally in an area, should one RCD section trip.
That’s a surprise to me . I assumed any CU is.
Anyway whichever solution you choose there are always ways and means of circumvention including pushing it a bit to famn right sculldughing and in reality the only way you have a real risk of getting done for it is if you do it dangerously or very dangerously.
PS - I didn’t say that!
Additional CUs are not specifically called out as notifiable, but "new circuits" are.
Maybe there is some corner case where you could add an addtional CU without creating any "new circuits" but.............
Brown, blue and green. Lewden and various others make similar ones.
While the dual efforts made from black phenolic still exist, they are really not something anyone should be using.
Not required and never was.
Main earth terminal.
Phenolics are brittle and are easily broken both by those installing them and by the usual junk that people insist on storing next to electrical equipment.
They also absorb moisture and become conductive, and when both L&N are in the same moulding, carbon tracks can form between them which eventually leads to breakdown and fire.
This example from a few weeks ago. All the cable holes bashed out leaving live parts exposed and a massive chunk missing from the top.
Also features knurled screws so it can be opened without tools. With the cover removed, both terminal blocks inside are loose and can fall out.
