- Joined
- 8 May 2017
- Messages
- 10,607
- Reaction score
- 2,851
- Country
If you remove the stat ,and connect the incoming live directly to the element ,does the RCD still trip instantly ?
Also; the photo seems to show water staining on the casing from above and above right of the 'mersion
Im getting 19 point something for L-N and no reading for the others.. the water staining is historicalWith the power off and stat disconnected as in your photo, get a multimeter and test resistances L-N, L-E, E-N.
If the pocket was leaking it keep on leaking and run out of the pocket.not running out of the pocket but if insert the thermostat into the pocket it comes out wet
That's good for the element itself; do you also have continuity through the removed thermostat terminals and no reading between thermostat terminals and brass body?Im getting 19 point something for L-N and no reading for the others.. the water staining is historical
He says he has done and it's still leaking.If you gently probe the pocket with an absorbsent probe to clear any water, and it re-appears then you need to replace the whole assembly, draining the cylinder.
