2-way switching problem
20 Nov 2010
Cornwall
Hello folks, today I fitted a second light switch in my garage so that there's a switch by each entrance, and wired it up to the original switch.
When I turned the power back on, I found that the new switch works but the old one now doesn't do anything!
The old one is a two-gang switch that also controls an outside light, which still works...
Unless they used to make two-gang switches that were one-way , I'm wondering if the old switch (from the 50s or 60s maybe) might be faulty...?
Any ideas on this would be appreciated
What he shows is correct, unless the original switch failed at the same time as rewiring it it'll be wired incorrectly.
the switches are generally laid out in a triangle with the common on it's ownand the matching physical locations should be 'matched'
Earthwires not shown for clarity
The terminals are not always marked the same - pictures of the switches markings make it so much easier for us.
