Problem wiring VIDEX 3112A
8 Jan 2026
Hello, I decided to replace my old Videx intercom because was old and ugly with newer one but now I have an issue when I try to connect the wires because it doesn't work or I connect the wires wrong.
I will attach down some pictures with the old and new intercom. I really appreciate any help, thank you.
Old intercom:
New intercom:
It won’t work ….you need a buzzer version ….not electronic ringer …eg 3102 this is the dual version works with both …
Follow the same numbers that are inprinted in the old handset …
Blue …with white ………6
White with blue …………2
Orange with white ………1
White with orange ………4
Green with white…………5
White with green ………..3
I've done that but I hear a weird noise from downstairs the buzzer it's always active and door opened.
For example what is the difference between Green with white and White with green? I have one wire full green and one white with green.
I found this diagrams:
There are 8 cores in a cat5 cable, the primary colour conventionally goes first, so green/white signifies green primary, white secondary, basically the one with most green is green, the one with white, and a side of green, is white green.
