Recomendation for a palm router and planer
30 Aug 2010
London
Hi there. Could you please recommend a palm router and a planer. I do a lot of DIY and I dont really buy cheap entery line power tools. I'd be grateful if you could propose a couple mains and battery powered quality options.
I have the DeWALT DCK266P2T Brushless Combi and Impact driver with 18V (5.0Ah) batteries. So it might be convenient to use them with a bat operated palm router or planer.
Ryobi are currently running their promotion, buy a battery+charger and get a free tool.
Their 18v router isn't too bad at all.
I only work in domestic properties. When using my router or planer, both are connected to my dust extractor (read: vacuum cleaner with auto start). Whilst working, I need to control the hose, keeping an eye on the power lead is no biggy. I see no advantage to using battery versions of either. It's not like I will be using them up a ladder. Your usage might be different though. Oh and if I go for cordless tools, I will need to pay over £100 for the module which connect to my dust extractor.
I have a small corded palm router- unfortunately it doesn't have dust extraction but it was gifted to me. My larger router is a half inch Dewalt with a dust extraction port. My planer- again a Dewalt. It is not brilliant (the rebate depth is about 12mm). If my pockets were deeper I would buy the Festool one, it only has a single blade. The blade is at an angle, so you get a cleaner cut rather than having two opposing blades that are set at very slightly different depths.
I do have cordless combi drills though.
I've got a Festool midi dust extractor. Corded router and planer could work for me and would make sense if I want to use dust extraction.
It would be nice to get a Festool but I won't use it often enough to justify the cost.
The palm router will get much more use so a recomedation for a good courded one with dust extraction would be good. I'd like it to be compatible with dovetail jig if possible.
