Refitting a fallen kitchen cupboard to a plasterboard stud wall
26 Jun 2007
The main cupboard in my kitchen recently fell off the wall. Put up by a previous owner, it transpired that the two hangers were each secured with two plasterboard fixings. Not what I would have done. My wife’s fondness for stuffing cupboards with tins & jars must have reached critical load and pulled the right-hand plasterboard fixings straight out. Luckily, she was there to hold it upright and catch some of the falling contents, but the broken glass and sticky mess everywhere was unbelievable.
I’m hoping I can repair the damaged corners of the cabinet with internal brackets, but that’s another problem. I’ll need to reattach it (else a replacement) rather more securely than before.
Based on related posts here and elsewhere, I was planning to use a long hanger rail to secure into the wooden studs. Are Hafele better quality than any one else’s?
I’ve found the vertical studs, spaced at 450mm. Three would fall behind the cabinet. To the right, the bracket will attach to the hanger rail neatly screwed between two studs.
But to the left, that cabinet bracket will be 180mm beyond the nearest stud. I can’t go further to secure the rail to the next stud along, because that’s behind the next cabinet. Removing that too, would not make me popular. I could try a (hateful) plasterboard fixing for that last rail support, but it’d be right where the left cupboard hanger is still attached, and removing that & its two fixings would leave ever more weakened plasterboard to put another plasterboard fixing in to. Maybe worse than leaving it alone.
Other threads suggest cutting a 100mm tall, long horizontal channel to expose the vertical studs, then fill it with plywood no thicker than the plasterboard it replaces. That would let me screw the rail through the ply into the joists (what size screws are best?) and also some shorter screws into the gaps between joists bridged by the plywood.
I’ve also read some suggest that full size noggins should be screwed between the vertical studs, with plywood on that, so full length screws can be run all along. But as mentioned, I can’t see how a noggin could be run beyond the left most stud with an intact cabinet in the way.
What so you people think? I assume the left-hand bracket would not be safe in the rail was unfixed 180mm beyond the left stud? Would running plywood (without noggin) that far beyond the stud be better?
Separately, should I fit a batten under the cupboard as well?
I often use Hafele but if you are purchasing a 1mm long rail and cutting it down, I would just ebay it. It is just a length of metal with holes in it.
My advice would be to use a slightly blunt drill bit to drill a series of holes into the plasterboard. The blunt bit will struggle to drill into the timber (which will let you know where the timber is). If the timber does not match the slots in the rail, drill a new hole in the full length rail. 5 by 50mm screws should be fine. Belts and braces, you could some interset fittings for the plasterboard section.
What do you think about cutting a channel and running plywood? The idea of Plasterboard fixings won't help me sleep at night.
P.S. Passing thought. The two adjustable brackets to top left & right of the cabinet appear to be held on by two screws each, each going into a side panel of 19mm thick chipboard. I know it's chipboard from where the corners broke as it fell. Once plasterboard fixings are removed from the situation, surely either pair of screws into chipboard are the weakest link in the load bearing chain?
I mean, why are we sinking multiple 5x 70mm screws into studs and maybe into extra noggins too, if those short screws are all that keep the cabinet from dropping?
It’ll be fine. Put screws into the studs, and… whatever… into the plasterboard at the end of the rail. And relax.
The correct method for fixing wall units to a plasterboarded stud wall where you cant find a timber is to cut the plasterboard out between the studs and fit a timber noggin.
Reattach plasterboard and fit the mounting plates through the plasterboard and into the noggin.
If you are lucky you wont need to make good the plasterboard as the wall unit hides the damage.
Ive never had a cabinet bracket which is held on with two tiny screws fail. It is not only held on with two screws the bracket has two precast plastic dowels which are pressed into the cabinet gable, the bracket is very difficult to remove.
is this a partition wall or has it got some kind of a brickwall behind and has just been battened out and paster boarded ? rather than dot dab - OR a dividing partition
Thanks. As for relaxing, please remember I now have PTSD;)
The only problem being the last 180mm run to the Left fixing where I don't have access to do this. Do you agree with @foxhole that this amount of rail can be unsecured?
Well that's reassuring to know.
Sadly it's stud/plasterboard throughout, with a great deal of booze on the shelf the other side of the wall. That coming adrift would be a real tragedy.
Fair enough, but if the rail is the full (internal) width of the of the unit and you are hitting two upright joists, what is gained by adding a nogging?
You do this kind of stuff day in day out, I may do it once a year but I find the full length brackets to be great. I have, previously used them on 9" Victorian brick walls with thick plaster walls where I could not get decent fixings with the supplied small hanging rails.
There is no point in putting a noggin in, if the above is the case, but the OP wrote that the wall unit was held on with plasterboard fixings which aren't suitable as a stand alone fixing in plasterboard.
The full length wall plates are brilliant, but they dont always solve the stud partition issue. Whereas you can buy 2.4mtr wall plate rails which have loads of fixing points, but you have to cut the gable so the bracket hooks engage and pull the unit to the wall.
If I cant find a work around I will use toggles, with the addition of an 18mm ply board screwed and CT1'd to the wall and then screw the gables to the ply.
No I dont agree with foxhole. At this point use a hollow wall anchor and CT1 the bracket to the plasterboard. Leaving it unsupported will allow the wall unit to flex on the unsupported section.
