Hi
I'm having some issues trying to fix my new shower screen to the wall. The wall is a tiled plasterboard wall, with a metal stud behind it. It is 32mm thick in total, being approx:
10mm tile --- 20mm plasterboard --- 2mm metal stud
I've looked at:
- solid wall plugs - don't think these would work in the plasterboard as it's not deep enough
- rawlplug spring toggles - too wide (would need to drill a 11mm hole) and wouldn't open because of the metal stud 30mm in
- poly-toggles, can't find any long enough to fix through the wall (all too short to open behind the metal stud)
- wall plugs for cavity walls - again because the metal stud is ~30mm deep, don't think these would be able to open properly
Any ideas what else I could use / would any of the above work?
Ideally the screw needs to be 4mm otherwise will need to widen the holes in the shower screen wall rail.
Thanks,
Roger
I've looked at:
Thanks,
Roger
