Fitting B&Q drawers to 15mm kitchen cabinets
26 Jan 2026
Hello. So i purchased a 600mm deep drawer as a test for my 600mm cabinet, which has 15mm instead of 18mm frame width. So when i fit the drawer it seems to be sticky. And does not open or close smooth. Do i need to place 3mm spacer between the drawer slider and the cabinet to enable it to work?
Try using washers on screws to pack it out, you may need slightly longer screws.
Thank you George, I can get 3mm rubber spacers, I will get a set and test again. Good point on the longer screws, would you know where I could get the same screws that are used today but longer. I will go a search and see what I can find.
You will need to pack both sides otherwise the draw front will be off center and i doubt there will be enough adjustment to correct it.
Use washers as suggested.
Thank you, i was planning on putting a spacer on both side, so as to keep things square. Washer are a great plan as suggest to get the extra space. As i can go up or down on each side as need to get the correct center. For now there wont be an external drawer front. but it all things work out then i could consider the route of new fronts.
