So, as long as I keep the top wires and bottom wires consistent, across each switch (e.g. red on top and white on bottom for the top switch in my original post it will switch OK? Thanks, David
You can build your assembly with MK GRID and it will look just like the 4 way MK switch you first posted
With a little care you can even replace the back piece of the switch you have purchased with an intermediate module, though dont attempt if not confident
