- Joined
- 6 Feb 2026
- Messages
- 10
- Reaction score
- 0
- Country
I’ve messed around with something I probably shouldn’t have, and now I’m trying to work out the cause of water dripping from above a window (see attached photos).
The area was damp, so I opened it up to check for a leaking pipe. Instead, I found metal mesh supporting concrete. I also used an endoscope camera but couldn’t see any obvious leaks.
The external window seal appears to be intact, and there are no visible issues with the bathroom or radiator nearby.
The property has cavity wall construction.
Any ideas on likely causes or what I should check next would be appreciated
