- Joined
- 2 Dec 2004
- Messages
- 718
- Reaction score
- 8
- Country
Hi all.
My girlfriends flat is electric only, no economy 7 fitted.
There are several radiant panel heaters installed in the rooms, each one just with a 13A plug. The panels have no in built thermostat, they are just on or off.
There is no central thermostat or timer/programmer for the heating.
There is also a mains pressure hot water cylinder, heated using two immersion elements. These are wired direct into 13A fused spurs, again no programmer/timer.
How can she upgrade this system to have central thermostat and timer control?
We would need devices capable of switching 13A electric panels. Ideally controlled by a single (or maybe two) centrally located room thermostats, and allowing centralised programmer /app functionality. Including the hot water programming ideally.
Having the hot water on a timer might at least allow exploration of overnight cheaper rate electricity tariffs.
Going to gas is impossible, and going to economy 7 probably not an option.
Any ideas or alternatives?
Thanks.
Thanks.
