- Joined
- 18 Nov 2025
- Messages
- 75
- Reaction score
- 4
- Country
Thanks for replying, this was under some slabs with a bush next to it, I think the roots from the bush grew and cracked the slabs and cement so I’ve removed them (and the bush!) but was worried the pipe/bend the downpipe is cemented into could be asbestos which fell away while I was tidying upYou do come across asbestos pipework above ground but that is just normal, old, fireclay. Nothing to worry about.
Thanks for the reply the downpipe definitely needs replacing as it’s leaving a huge damp patch on my brickwork with all of this wonderful weather we are having. It looks a little damp around this broken pipe so I’ve asked a builder to have a look and see what he thinks the best thing to do is.If the water is going in to the drain ok then just leave it alone. If not then a plumber can fix it.
Pretty sure the OP doesn't want to DIY it. You could visit and give them a quote.OP,
You asked for help - & I offered help. But since Saturday you have disappeared?
Absolutely no need to apologise, things happen. This is a public DIY forum and most are here to help, the fact that you aren't on here every minute to check for answers to your post/question and reply to them within hours usually wouldn't be an issue worth chasing. If no reply within a week then fair enough to ask.Hi really sorry, had a family emergency so haven’t been home in the day light the last couple of days.
Thank you for the replies. Daft question but would I need a plumber or builder to fix this? I’m wary of poking around it too much incase it’s really weak and I’ve no one on hand if it causes any other issues
